Working with Interface Groups and Aggregations › Edit Interface Aggregations
Edit a single interface aggregation to choose different interfaces to aggregate or to change the aggregation name, description, speed, or interface type.
- Display the Aggregations Interfaces page:
- Select Administration from the NFA console menu.
- Select Interfaces: Aggregations from the Administration page menu.
The Interface Aggregations page opens and shows a list of the current interface aggregations.
- Click the check box next to the aggregation that you want to edit, then click Edit.
The page changes to the Edit Aggregation view, which includes editable options.
- Make any changes that are needed, such as adding or removing interfaces or changing the aggregation name, description, in/out speed, or type.
- Click Save.
Your changes are saved and you return to the list of aggregations.
Copyright © 2014 CA.
