Previous Topic: Working with Interface Groups and AggregationsNext Topic: Edit Interface Aggregations
Create Interface Aggregations
Create interface aggregations to combine traffic from two or more interfaces so the traffic is reported together.
For example, suppose that you create aggregations for each of several geographical regions. Operators use the aggregations in reports to review and compare the totals for specific regions. Before you created the aggregations, operators had the following problems:
  1. Display the Interface Aggregations page:
    1. Select Administration from the NFA console menu.
    2. Select Interfaces: Aggregations from the Administration page menu.
      The Interface Aggregations page opens and shows the list of current interface aggregations.
  2. Click New.
    The page changes to show options for adding an aggregation.
    Select interfaces to add to the aggregation by using any of the following methods:
  3. Specify the following values, then click Save:
    The aggregation is automatically deployed within one minute of creation.
