Previous Topic: Stacked Protocol TrendNext Topic: Interface: ToS Summaries
Stacked ToS Trend
The Stacked ToS Trend views show the interface traffic for the top ToS, including the time the traffic occurred.
The example graphic shows a Stacked ToS Trend view in the CA Performance Center Console. A timeline of rates is included for each ToS value. You can configure the view to display rate, utilization, or volume information.
The Stacked ToS Trend view shows the top ToS values for traffic on the interface.
The view includes the following information:
Identifier
Identifies the interface that is used for the report. The identifier string consists of the router name, interface name, and interface description (under the view title).
(NPC) The identifier line also includes the interface speed.
ToS Bands
Show the data rate, data volume, or interface capacity utilization for each top ToS that is associated with traffic on the interface.
Time
Point in time during data transmission expressed in hours and minutes (X-Axis).
Measurement Setting:
Depending on the data direction, the view shows inbound, outbound, or total data on the interface.
Legend
Identifies the ToS for each color band by ToS number and label (bottom of the view).
Performance Center views show the data from the time range that is defined for the page.
Opening the View
To see this view in the Performance Center Console, go to one of the following locations:
Note: You can add Multi-Interface Stacked ToS Trend views to a custom dashboard or to a custom tab in the Interface pages of the CA NetQoS Performance Center Console. This view consists of a group of interface-specific stacked ToS trend charts
Available Actions
You can perform several actions in this view, including the following ones:
Find ToS Trend Data in the NFA Console
You can display ToS volume in trend charts or stacked trend charts in the NFA console for a selected interface:
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
