In a three-tier distributed deployment, each DSA is installed on a separate server. Complete the steps in this topic to upgrade a DSA on a dedicated Windows server or virtual machine.
Note: If you have a Linux DSA, contact your CA Support Availability Manager or Sales Account team to inquire about obtaining a Windows-based DSA.
If the server fails the JRE pre-requisite check, an error message opens and you cannot proceed.
The License Agreement screen opens.
Prerequisite tests look for problems and may cause an error message to open.
The Choose Install Folder screen opens and displays the original root installation path as the default setting.
Important: You must use the original installation path or the upgraded software will not run properly.
If the program does not find certain directories in the installation path, an error message opens and the upgrade stops. This problem does not occur when the previous software installation is fully functional.
The Select a Location for the MySQL Data Directory screen opens, which shows the original installation path for the MySQL data directory.
The Folder Selected Is Not Empty message also opens, which asks you to verify that you have backed up the directory contents.
Important: You must use the original installation path for the MySQL data directory.
The Select a Location for the MySQL Temp Directory screen opens, which shows the original installation path for the MySQL tmp directory.
Important: You must use the original installation path for the MySQL temp directory.
MySQL51 is configured, then the Pre-Installation Summary screen opens.
The Installing DSA screen opens. When the upgrade is complete the Install Complete screen opens and reports any errors that occurred.
The upgrade program closes. The DSA is upgraded and the DSA services are restarted.
The migration of DSA database table data begins as soon as the CA NFA DSALoader service restarts. The DSA_Install log lists the tables as they are migrated. Nine tables are migrated for each agent or interface. If you have many agents and an extensive amount of stored data, migration may continue for some time.
Next:
