Previous Topic: View the SNMP Profiles ListNext Topic: Verify IP Domains
Add SNMP Profiles
Administrators can create SNMP profiles in the Console for CA Performance Center or CA NetQoS Performance Center. You can create SNMPv1/v2C or SNMPv3 profiles.
  1. Log in to the Console for CA Performance Center or CA NetQoS Performance Center as a user with the Administrator role.
  2. Display the list of SNMP profiles:
    The page displays the current list of SNMP profiles.
  3. Click New.
    The Add SNMP Profile dialog opens.
  4. Complete the fields and change default settings as needed. Some fields apply only to SNMPv3 or SNMPv.1/v2C
    Profile Name
    Defines a name for the SNMP profile. Profile names must be unique, cannot be duplicated across SNMP versions, and are not case-sensitive.
    SNMP Version
    Specifies the version of SNMP that the profile uses. Because SNMPv1 and SNMPv2C are similar from a security standpoint, they share a single option. SNMPv3 is a separate option.
    Port
    (Optional for SNMPv1/v2C) Identifies the port that is used to make SNMP connections to devices associated with this profile.
    Default: UDP 161.
    User Name
    (SNMPv3 Only) Identifies the user for the profile, whose secret keys were used potentially to authenticate and encrypt the SNMPv3 packets. The User Name is a character string.
    Context Name
    (SNMPv3 Only) Specifies a collection of management information that is accessible by an SNMP entity. The Context Name is necessary for providing end-to-end identification and for retrieving data from an SNMPv3 agent. The Context Name is an octet string.
    Community Name
    (SNMPv1/v2C Only) Defines a secure string that lets the data source query the MIB of the associated device. The community that you supply must provide read-only access to the device MIB.
    Note: In the default SNMP profile, the community is 'public'.
    Verify Community Name
    Confirms the secure community string (name).
    Authentication Protocol
    (SNMPv3 Only) Specifies the authentication protocol to use when contacting devices associated with this profile. The following algorithms for authenticating SNMPv3 packets are supported:
    • None (do not attempt authentication)
    • MD5 (Message Digest 5)
    • SHA (Secure Hash Algorithm)
    Authentication Password
    (SNMPv3 Only) Specifies the password for authentication using SNMPv3 and the selected authentication protocol.
    Note: For SNMP profiles that are used with CA Network Flow Analysis make sure you specify a password that is at least eight characters long. If the password does not meet this requirement, the SNMP profile will be invalid and no SNMP data will be returned when the SNMP profile is used for polling. In this case the corresponding interfaces and devices in views, reports, and dashboards are missing device names, interface names, interface speeds, and interface utilization data.
    Verify Authentication Password
    Confirms the authentication password.
    Privacy Protocol
    (Optional) Specifies the encryption protocol to use for data flows sent to any devices or servers associated with this profile. Select one of the following protocols to create a valid SNMP profile for CA Network Flow Analysis polling:
    • None (do not encrypt communications)
    • DES
    • AES (128-bit encryption)
    • Triple DES
    Note: If AES 192 and AES 256 options are listed, do not select either of those options: They are not supported for CA Network Flow Analysis. If the SNMP profile you create is not valid, no SNMP data is returned for devices and interfaces that use it. In this case the corresponding interfaces and devices in views, reports, and dashboards are missing device names, interface names, interface speeds, and interface utilization data.
    The privacy protocol option is not enabled until authentication is enabled for this profile.
    Privacy Password
    Defines the password used when exchanging encryption keys. See the Note for a possible length requirement.
    Verify Privacy Password
    Use by default for new devices (CA PC)
    Enable this profile for auto-discovery (NPC)
    Specifies whether the profile is used by default to contact any new devices that are discovered from monitored traffic. If it fails, the next profile in priority order is used. Disable this parameter to exclude a profile from discovery.
  5. Click Save.
  6. You return to the list of SNMP profiles. The new profile appears in the list.
    CA Performance Center or CA NetQoS Performance Center performs a global synchronization to send the profile information to CA Network Flow Analysis.
