Administrators can set the domain assignment for Harvesters, routers, interfaces, and custom virtual interfaces (CVIs). We recommend that you set up any custom tenants and domains you need before you add the Harvesters.
Having the appropriate IP domains set up helps to achieve the following goals:
For example, suppose a router with a single IP address has interfaces that belong to different enterprises. The domain identifiers clarify that the interfaces are different managed items, even though they have the same IP address.
The Default Domain is created automatically. The Default Domain includes any items that are not assigned to a custom domain.
The Manage IP Domains page opens and displays the current domains.
The current domains are shown under All Domains.
If you have not created any custom IP domains, only the Default Domain appears in the list.
The IP Domains Administration dialog opens.
The Add Domain dialog opens.
Identifies the domain.
(Optional) Describes this domain namespace, such as naming the enterprise that owns it.
(CA PC only) Indicates the alias to use for a managed device. A device alias is a user-configured name that is applied to the associated managed item in CA Performance Center. Click Browse to navigate to and import a CSV file of aliases. The CSV file contains a comma-separated list of IP address-to-device alias mappings.
Aliases that are associated with the primary IP address of a device take precedence over aliases that are associated with any secondary IP addresses. Look for the primary IP address in the Address column of the Inventory Devices list. We recommend always using the primary IP address of the device in the CSV file.
For example:
172.24.36.107,Austin Router
Browse to select the file and click Open.
If you include aliases for devices you are managing already, it can take up to 5 minutes to begin synchronizing these aliases with CA Performance Center.
Note: To remove an alias, import a CSV file that includes the IP address for the device and a blank alias column. To change an alias, modify the alias entry in the CSV file and reimport the file.
(CA PC only) Indicates the alternate description to use for an interface. Interface descriptions appear in CA Performance Center already, but you can provide an alternate description. Click Browse to navigate to and import a CSV or TXT file of alternate descriptions. The file contains a comma-separated list of values that include the device IP address, interface name, interface description, and alternate interface description (alias) mappings.
For example:
172.24.36.107,ethernet_7,vmxnet3 Ethernet Adapter,Connection to Dallas
Note: Use the primary IP address of the associated device in the CSV or TXT file. Secondary IP addresses are not supported. Look for the primary IP address in the Address column of the Inventory Devices list.
If you include alternate descriptions for interfaces you are managing already, it can take up to 5 minutes to begin synchronizing these descriptions with CA Performance Center.
Note: You can use the same alternate interface descriptions for more than one interface.
To remove an alternate description, import a CSV or TXT file that includes the IP address for the device, the interface name, the interface description, and a blank alias column. When you remove an alternate description, the original interface description reappears in CA Performance Center views.
Important! If you use a spreadsheet program to remove all of the alternate descriptions from a CSV file, include a column heading for the interface description override column in the imported file. If you do not include this column heading, the original interface descriptions will not reappear in CA Performance Center views.
To change a description, modify the alias entry in the CSV or TXT file and re-import the file.
(CA PC only) If selected, displays the Primary DNS/Port and Secondary DNS/Port options.
Is the IP address of the primary name server for this domain.
Is the port number that the primary name server uses.
Is the IP address of the secondary name server for this domain. Can be the same as the primary address.
Is the port number that the secondary name server uses.
(NPC only) Indicates whether the proxy address is enabled for this IP domain.
(NPC only) Is the IP address of the DNS proxy server.
This setting is required only if your network is located behind a DNS proxy server.
The new IP domain appears on the page.
