Use the steps in this topic to install the Flow Cloner.
The installation server must have the CA Network Flow Analysis 9.2.0 Harvester software installed.
The Pre-Installation Summary screen opens and shows the installation path and disk space requirements. The Flow Cloner will be installed in the same root installation directory that is used for the Harvester or stand-alone software.
The status bar and pop-up messages show the progress of the installation. The Install Complete screen opens when the installation is complete.
The installation program closes. An installation log file named FlowCloner_Install_<timestamp>.log is created in the root installation directory.
Next: Configure the Flow Cloner options.
