Previous Topic: Install the Flow ClonerNext Topic: Examples of Flow Cloner Configuration Files
Configure Flow Cloner Options
To configure the Flow Cloner, modify its default initialization (.ini) file. The .ini file contains a header line followed by a line for each destination host--each host that will receive the cloned packets. If you do not specify values for the header fields, the default values are used. You must specify at least one destination host.
For information about the configuration file conventions, including how to comment out lines or fields, see Conventions for Flow Cloner Configuration Files.
  1. Log in to the Flow Cloner installation server as a user who has administrator privileges.
  2. Open the following file in a text editor: <install_path>\Netflow\FlowCloner\flowclonedef.ini.
    The .ini file has a header line followed by a line for each host that will receive packets.
  3. Customize the header line:
    The header content must be contained in a single line,--the first non-commented and non-blank line in the file.
    For examples, see Examples of Flow Packet Cloner Configuration Files.
  4. Specify one or more hosts that will receive the cloned packets:
    Enter each host on a separate line, which consists of the dest ip= token and IP address of the destination host. You can put the destination host lines in any order.
    Example:
    /dest ip=10.0.0.100 ; send cloned packets to to 10.0.0.100
    If the IP address is missing, the line is ignored.
  5. Save and close the FlowCloneDef.ini file.
  6. Start the CA NFA Flow Cloner service on the Harvester server.
    The Flow Cloner is enabled and attempts to forward packets to each valid destination that you specified. Flow cloning continues until you stop the CA NFA Flow Cloner service manually.
    The CA NFA Flow Cloner service is configured to start automatically on reboot and start sending cloned flow data. To operate the Flow Cloner only on demand, change this configuration in the Services window. The service cannot run if the configuration file does not identify at least one destination IP address.
Also see:
