Initial Configuration › Configure CA Network Flow Analysis to Work with Performance Center › Verify That Data Is Received › Verify That the Interfaces Are Enabled
Once you configure CA Network Flow Analysis to receive flow data, verify that the expected interfaces are monitored.
- Open the NFA console, logged in with Administrator rights.
- Open the Available Interfaces page:
- Select Administration from the NFA console menu.
- Select System: Enable Interfaces in the Administration menu.
The Available Interfaces page opens.
- Expand the router details to display the interface list: Click the arrow to the left of the router name.
- Review the list to review whether the interfaces are enabled.
- Change the interface status: Select the check box next to one or more interfaces, then click Enable or Disable.
The selected interfaces are immediately enabled or disabled.
- Repeat these steps for each router.
