Previous Topic: Verify the Harvester DomainNext Topic: Add DSAs (Three-Tier Deployment)
Set Up the Routers
Enable NetFlow on each CA Network Flow Analysis router by completing the steps in this topic. You can configure routers to export any of the following flow protocols:
Note: Configure flow from each source to be exported to a single Harvester. If flow from one source is exported to multiple Harvesters, a number of problems result. If this occurs, contact CA Support for help.
Complete these tasks:
  1. Back up the current router configuration.
  2. Configure NetFlow export for each interface individually:
    1. Set the flow export version.
    2. Set the flow source IP address. Cisco recommends that you configure a loopback source interface. The IP addresses of non-loopbacked interfaces can change.
    3. Set the flow destination IP address and set the destination port to 9995. If you are using a custom value for the harvester listening port, use that value as the destination port. The port values must match or the Harvester does not receive flow data.
    4. Set the flow expiration timeout to 1 minute.
  3. Enable flow for each interface.
  4. Configure SNMP index persistence on each router that supports this feature.
