您必须编辑某些配置文件以反映新的网站和端口设置。 编辑配置文件,将 HTTP 连接器替换为 HTTPS 连接器。 您还必须重新启动 CA Performance Center 服务,才能使更改生效。
遵循这些步骤:
cd/[InstallationDirectory]/CA/PerformanceCenter/PC
#/opt/CA/PerformanceCenter/PC/etc/jetty-ssl.xml
其中,“/opt/CA”是默认安装目录。
cd/[InstallationDirectory]/CA/PerformanceCenter/PC/etc
<?xml version="1.0"?>
<!DOCTYPE Configure PUBLIC "-//Jetty//Configure//EN" "http://www.eclipse.org/jetty/configure.dtd">
<Configure id="Server" class="org.eclipse.jetty.server.Server">
<Call name="addConnector">
<Arg>
<New class="org.eclipse.jetty.server.ssl.SslSelectChannelConnector">
<Set name="Port">8182</Set>
<Set name="maxIdleTime">30000</Set>
<Set name="Keystore"><Property name="jetty.home" default="." />/etc/keystore</Set>
<Set name="Password">***PASSWORD***</Set>
<Set name="KeyPassword">***PASSWORD***</Set>
<Set name="truststore"><Property name="jetty.home" default="." />/etc/keystore</Set>
<Set name="trustPassword">***PASSWORD***</Set>
<Set name="allowRenegotiate">true</Set>
</New>
</Arg>
</Call>
</Configure>
<Arg>
<New class="org.eclipse.jetty.server.nio.SelectChannelConnector">
<Set name="host"><Property name="jetty.host" /></Set>
<!-- Changed: Used to be Property -->
<Set name="port"><SystemProperty name="jetty.port" default="8181"/></Set>
<Set name="maxIdleTime">300000</Set>
<Set name="Acceptors">2</Set>
<Set name="statsOn">false</Set>
<Set name="confidentialPort">8443</Set>
<Set name="lowResourcesConnections">20000</Set>
<Set name="lowResourcesMaxIdleTime">5000</Set>
</New>
</Arg>
</Call>
cd/[InstallationDirectory]/CA/PerformanceCenter/PC/conf
wrapper.java.additional.2=-Djetty.port=8181
cd /[InstallationDirectory]/CA/PerformanceCenter/sso/webapps/ sso/configuration
<?xml version="1.0" encoding="utf-8" ?>
<Configuration>
<SingleSignOnEnabled>True</SingleSignOnEnabled>
<SingleSignOnProductCode>pc</SingleSignOnProductCode>
<SignInPageProductDefaultUrl>
<Scheme>https</Scheme>
<Port>8182</Port>
<PathAndQuery>/pc/desktop/page</PathAndQuery>
</SignInPageProductDefaultUrl>
<SingleSignOnWebServiceUrl>
<Port>8182</Port>
<PathAndQuery>/pc/center/webservice/sso</PathAndQuery>
</SingleSignOnWebServiceUrl>
</Configuration>
版权所有 © 2013 CA。
保留所有权利。
