Previous Topic: Browser Shows ErrorNext Topic: Check the Audit Log
Logs
By checking your log files daily or weekly, you can resolve problems before they affect normal operations. All logs are stored in subfolders that correspond to the relevant service (or daemon). Find log files in the following path:
CA/PerformanceCenter/<servicename>/logs
The servicename is one of the following names:
DM
The Device Manager.
EM
The Event Manager.
PC
The main console program.
SSO
The Single Sign-On authentication software.
For problems with the Single Sign-On Configuration Tool, check the application log in the following location:
/opt/CA/PerformanceCenter/sso/logs/application.log
Log filenames include the relevant date and time.
New log files are generated automatically each day. Older log files are removed automatically after 14 days to avoid consuming excessive disk space.
Access the most recent log file to find errors associated with the database or data source synchronization. You can start by opening the Events dashboard from the Dashboards tab and sorting by Status. If you want to look at the related log file, note the event type and failure date and time. In the log directory, open the log file with the corresponding date in the filename.
