Previous Topic: Generate and Import a CertificateNext Topic: Import an Existing SSL Certificate
Convert a Self-Signed Certificate to a Certification Authority SSL Certificate
A self-signed certificate prompts a browser warning when users open CA Performance Center. Users can manually dismiss the warning to continue. However, a certificate that a trusted Certification Authority has signed avoids the browser warning. The following procedure explains how you can convert the self-signed certificate to a certificate that a trusted Certification Authority has signed.
  1. Run the following command:
    cd installDirectory/PerformanceCenter/jetty/etc
  2. Export a certificate signature request using the following command:
    keytool -certreq -keystore keystore -storepass storepasswd -alias capc -keypass keypasswd -file requestFileName.csr
    requestFileName.csr
    Determines the path and file name of the exported signature request.
  3. Send the resulting file (requestFileName.csr) to a qualified signing authority, along with any other requested information.
    The Certificate Authority sends you a signed certificate (signedCert.cer). They might also provide a root Certificate Authority certificate (rootCA.cer) to authenticate the signed certificate.
  4. Determine whether the root Certificate Authority certificate is part of the default java trusted authorities using the following command:
    keytool -list -v -keystore installDirectory/jre/lib/security/cacerts -storepass cacertspasswd
  5. Search the output for the Certificate Authority that signed your certificate. If the Certificate Authority is not listed, add it to the list of trusted authorities using the following command:
    keytool -importcert -keystore installDirectory/jre/lib/security/cacerts -storepass cacertspasswd -alias myRootCa -file rootCA.cer
  6. Import the signed certificate using the following command:
    keytool -importcert -trustcacerts -keystore keystore -storepass storepasswd -alias capc -keypass keypasswd -file signedCert.cer
  7. Validate the contents of the jetty keystore using the following command:
    keytool -list -keystore installDirectory/PerformanceCenter/jetty/etc/keystore
    The single certificate that you imported appears in the list.
  8. Restart each CA Performance Center service using these commands:
    /sbin/service caperfcenter_sso restart
    /sbin/service caperfcenter_devicemanager restart
    /sbin/service caperfcenter_console restart
    The Certificate Authority SSL certificate replaces your self-signed certificate in the keystore.
Next step: Configure the port and website to support HTTPS.
