If you do not already have an SSL certificate, you can generate one using the keytool command. This procedure explains how to generate a self-signed certificate and install it in the keystore.
cd installDirectory/PerformanceCenter/jetty/etc
mv installDirectory/PerformanceCenter/jetty/ etc/keystore installDirectory/PerformanceCenter/ jetty/etc/keystore.bak
Important! You must remove the old keystore. If you do not, an error appears in later steps: "Keystore was tampered with, or password was incorrect."
keytool -genkeypair -keystore keystore -storepass storepasswd -keyalg RSA -keysize 2048 -keypass keypasswd -alias capc
Determines the password to access the keystore.
Determines the password to access the key within the keystore.
Important! Remember these passwords—they cannot be recovered.
keytool -exportcert -keystore keystore -storepass storepasswd -alias capc -file filename.cer
Determines the file to which the certificate is exported. We recommend using a full pathname that does not place the file in the current directory.
Example: /tmp/capcCert.cer.
Note: We recommend backing up the cacerts file before continuing.
keytool -importcert -keystore installDirectory/jre/lib/security/cacerts -storepass cacertspasswd -alias capcSelfSigned -file filename.cer
Note: The default password for the cacerts keystore is "changeit."
Specifies the password for the cacerts keystore.
Default: changeit
The file to which the certificate was exported in a previous step.
keytool -storepasswd -keystore installDirectory/jre/lib/security/cacerts
You are prompted to provide the existing password and the new password.
keytool -list -keystore installDirectory/jre/lib/security/cacerts
Important! To enable the web services, the self-signed certificate must be in the cacerts keystore. Otherwise, you see an error in the log that reports that PKIX did not find a certificate.
/sbin/service caperfcenter_sso restart
/sbin/service caperfcenter_devicemanager restart
/sbin/service caperfcenter_console restart
Your self-signed SSL certificate is generated and installed in the keystore.
Next steps:
