When you change settings using the Configuration Tool, your settings are saved in configuration files. Create backup copies of these files on a regular basis to avoid losing Single Sign-On settings. Use rsync or another preferred method, such as a script, to back these files up automatically or before an upgrade.
Add the following files to your backup procedures:
InstallationDirectory/CA/PerformanceCenter/sso/start.ini InstallationDirectory/CA/PerformanceCenter/PC/start.ini
Also back up the following directories:
InstallationDirectory/CA/PerformanceCenter/sso/webapps/sso/configuration InstallationDirectory/CA/PerformanceCenter/sso/etc InstallationDirectory/CA/PerformanceCenter/sso/conf InstallationDirectory/CA/PerformanceCenter/PC/etc InstallationDirectory/CA/PerformanceCenter/PC/conf
Note: The default installation directory is /opt/CA.
