Before you upgrade a CA Network Flow Analysis 9.1.00 or 9.1.1 deployment, back up the databases and files in the following table.
Important:
Database |
Description |
Standalone Server |
Harvester Servers (Distributed) |
NFA Console Server (Distributed) |
reporter |
Enterprise Overview data and NFA console configuration data |
Important |
Important |
harvester |
Harvester configuration data |
Important |
Important |
poller |
Poller configuration data |
Important |
Important |
ReaperArchive15 |
Historical (15-minute) data |
Recommended |
Recommended |
Customized Files |
Configuration or other files that have been customized |
Important |
Important |
Important |
Customized data_retention |
Settings to regulate data retention |
Important if customized |
ReaperArchive |
Realtime (1-minute) data |
Optional, rarely backed up |
Windows Registry |
Settings for the Windows Harvesters |
Important (Windows Harvesters) |
The following list describes the databases and their locations:
Path: <NFA_Install_Path>\MySql51\data\reporter directory
Path: <NFA_Install_Path>\MySql51\data\harvester directory
Path: <NFA_Install_Path>\MySql51\data\poller directory
Path: <NFA_Install_Path>\Netflow\datafiles\ReaperArchive15 directory
The CA Network Flow Analysis configuration files typically have a .config, conf., or .ini extension and are located in the product installation path. Other customizations may include .css files and report logos.
Path: <NFA_Install_Path>\Netflow\datafiles\ReaperArchive directory
Path: <NFA_Install_Path>\MySql51\data\data_retention directory
Back up the Registry as a .reg file by selecting File, Export in the Registry Editor window. For more information about the new location of Harvester settings, see the Release Notes topic "Relocation of Harvester Settings."
Next: Verify that the servers meet the installation prerequisites.
