Finishing the Upgrade Preparations › Back Up the Databases › Back Up 9.0.1 Databases
Before you upgrade a CA Network Flow Analysis 9.0.1 deployment, back up the following databases and files:
Database
Description
Standalone Server
Harvester Servers (Distributed)
NFA Console Server (Distributed)
reporter
Enterprise Overview data and NFA console configuration data
Important
Important
harvester
Harvester configuration data
Important
Important
nqrptr
Historical (15-minute) data
Recommended
Recommended
Customized Files
Configuration or other files that have been customized
Important
Important
Important
Windows Registry
Settings for the Harvesters
Important (Windows)
The following list describes the databases and their locations:
- reporter database: Back up the previous 24 hours of Enterprise Overview data, NFA console configuration settings, and synchronization information.
Path: <NFA_Install_Path>\MySql51\data\reporter directory
- harvester database: Back up the Harvester configuration data.
Path: <NFA_Install_Path>\MySql51\data\harvester directory
- Nqrptr database: (Recommended) Back up the historical (15-minute) data that is stored for the reporting routers and interfaces.
Path: <NFA_Install_Path>\MySql51\data\nqrptr directory
- Customized configuration files: Back up any customized configuration files--files that you customized or that were customized by CA Support. In addition, back up any customizations that you made to the website or reports.
The CA Network Flow Analysis configuration files typically have a .config, conf., or .ini extension and are located in the product installation path. Other customizations may include .css files and report logos.
- Windows Registry: Back up the Windows Registry on Harvester servers. Harvester Registry settings are converted to MySQL database settings during the upgrade.
Back up the Registry as a .reg file by selecting File, Export in the Registry Editor window. For more information about the new location of Harvester settings, see the Release Notes topic "Relocation of Harvester Settings."
Important:
- Make the backups run concurrently. If you restore data from backups that have different timestamps, problems can result. Ensure that your backed-up data files are timestamped with the same hour.
- Store backups to a remote location to guard against the possibility of a hardware or OS failure on the main server. For example, back up the databases to an administrative share or mapped network drive.
- Connect to the server:
- Open a remote desktop session.
- Initiate a Terminal Services or VNC session to the installation server.
- Copy each of the following directories or files to a remote location:
- Reporter database: Copy the following directory from the standalone server or the NFA console server of a distributed deployment: <NFA_Install_Path>\MySql51\data\reporter
- Nqrptr database: Copy the following directory from the standalone server or the DSA server of a distributed deployment: <NFA_Install_Path>\MySql51\data\nqrptr
- Customized configuration files: Back up any customized configuration files from the CA Network Flow Analysis installation path on any server. In addition, back up files that have been changed to customize reports, such as .css files and report logos.
- Restart the services.
Next: Verify that the servers meet the installation prerequisites.
