Previous Topic: Register CA Network Flow Analysis with CA Performance CenterNext Topic: Verify SNMP Profiles
Test Data Source Connections
In most cases, the status indicates that data source registration has completed successfully. If the status indicates an error, use the test feature on the Manage Data Sources page.
The Test button initiates a test to confirm that a new data source is registered and connected correctly. The test checks for version compatibility and verifies that the data source is not registered with a different instance of the CA Performance Center software.
If the test fails, verify that the server name or IP address is accurate for the source type. For more information, see Data Source Test Failed.
