Previous Topic: Merge InterfacesNext Topic: Delete and Disable Interfaces
Enable Interfaces
Interfaces are enabled automatically in CA Network Flow Analysis by default. You enable interfaces manually, however, in the following situations:
Enabling an interface causes the following events to occur immediately:
  1. Open the Available Interfaces page:
    1. Select Administration from the NFA console menu.
    2. Select System: Enable in the Administration menu.
      The Available Interfaces page opens.
  2. Click the arrow on the left edge of the row for the router that contains the interfaces that you want to enable.
    The view expands to show a list of the interfaces for the selected router, with Enabled status shown.
  3. Select the check box next to one or more interfaces.
  4. Click Enable.
    The selected interfaces are enabled immediately.
