Previous Topic: Work with InterfacesNext Topic: Enable Interfaces
Merge Interfaces
You can merge router interfaces so they are treated as one object in reports. You may want to merge interfaces for the following reasons:
  1. Open the Active Interfaces page:
    1. Select Administration from the NFA console menu.
    2. Select Interfaces: Physical & Virtual from the Administration menu.
      The Active Interfaces page opens, which lists the current routers and their active interfaces.
  2. Expand the interface list for a router by clicking the arrow on the left edge of the router row.
    The view expands to show a list of the interfaces for the selected router.
  3. Select the check box next to the two interfaces that you want to merge.
    The Merge button at the top of the page is activated and no longer appear dimmed.
    Note: The Merge button is active only when two interfaces are selected.
  4. Click Merge.
    The Merge Interface Confirmation dialog opens.
  5. Verify the information in the Merge Interface Confirmation dialog box as follows:
  6. Click Save.
    The selected interfaces are merged according to the values in the Merge Interface Confirmation dialog box.
