After you create a protocol group and operators run reports that use the protocol group as a filter, you may want to make changes.You may want to rename the protocol group to reflect the way operators are likely to use it. You also may want to change the list of protocols included in the group.
The Edit a Protocol Group page opens.
The name and description are updated in the Protocol Group Configuration page list and in the Protocol Group Index.
A table is added to the bottom of the page, which lists the protocols.
Note: The Domain setting is displayed only for an environment that has multiple domains configured.
For more information about the Domain setting, see Step 3 in Configure the Protocol Group.
For more information about this step, see Step 4 in Configure the Protocol Group.
The protocol group is configured with your settings. Operators can select the reconfigured protocol group as a filter for an Analysis or Custom report.
