After you create a shell protocol group, the next step is to configure the protocol group.
Configuration options are added to the Protocol Group Configuration page.
Note: The Domain setting is displayed only for an environment that has multiple domains configured.
The contents of the selected protocol group are displayed with the protocol names for the selected domain. If an administrator has defined domain-specific names for protocols, selecting that domain displays the appropriate protocol names.
The Domain setting does not restrict access in CA Network Flow Analysis to the protocol group or to the reports that use the protocol group as a filter.
A dialog opens, which shows a list of available protocols and a list of any protocols that are included in the list already.
Note: If the Add/Remove link is not visible, click List.
To select multiple protocols to add simultaneously, use the Shift and Control keys.
To filter the protocol list, enter a search string in the Filter the Protocol List field box, then click Apply. For example, to show only UDP protocols, enter *udp*.
The selected protocols are added to the protocol list.
The selected protocols are removed from the protocol list.
To review a list of protocol groups that contain a particular protocol, select the protocol and click 'Jump to Protocol.' The Protocol Configuration page opens and displays a list of all the protocol list that contain the selected protocol.
The protocol group is configured with your settings. Operators can select the configured protocol group as a filter for an Analysis or Custom report.
Note: Operators can define reports only if their user settings are set up to enable this capability.
