Creating Analysis reports for your organization helps to troubleshoot various issues. Analysis report definitions are saved so you can generate an updated report at any time or can use the report definition as a template to create another report. As the number of reports grows, use the folder management system to keep the report definitions easy to find.
The report folders are listed on the left. The Analysis Reports folder is a built-in folder, which you can rename, but cannot delete. Create additional folders to provide more extended organization for your Analysis reports.
The right pane displays the names of the Analysis reports in the currently selected folder. Use the links at the top and bottom of the pane to delete or run selected reports, and to create or move report definitions.
