Individual CA Network Flow Analysis operators and CA Performance Center operators require data access permissions to monitor data. Access permissions are based on groups. You can assign access permissions according to your plan for custom groups.
To assign permissions, edit the user accounts in the CA Performance Center console. Your goal is to make sure that all operators see only the data they require to do their job.
The Manage Users page opens.
The Add User wizard opens.
The wizard displays the Permission Groups page.
The selected permission groups appear in the Selected Groups pane.
When the user logs in, data from the default group appears in dashboards by default.
The changes are saved to the user account, and you return to the Manage Users page.
Custom groups have been created and assigned as permissions to IT staff. When staff members log in to CA Performance Center, they can view data from the systems that are assigned to them.
