Previous Topic: Initial ConfigurationNext Topic: Configure CA Network Flow Analysis to Work with CA Performance Center
Single Sign-On
The Single Sign-On tool authenticates you at start-up so you can log in once and can use several related products without logging in again. If you log in to CA Performance Center, for example, you can jump to information in CA Network Flow Analysis without logging in again.
Single Sign-On is installed automatically when you install CA Network Flow Analysis. For more information, see the Single Sign-On Guide, which is available at the CA Support site, http://support.ca.com.
Note: The Single Sign-On tool uses Lightweight Directory Access Protocol (LDAP), provided that LDAP is set up. The Single Sign-On tool does not use LDAP by default.
