Previous Topic: Verify IP DomainsNext Topic: Add Custom IP Domains
View the IP Domains List
IP domains are required for monitoring multiple environments with overlapping IP addresses. Set up all the domains that you will need before you begin to send flow data to CA Network Flow Analysis.
  1. Log in to the CA Performance Center console as a user with the Administrator role.
  2. Click Admin, User Settings, and IP Domains.
    The Manage IP Domains page shows the current list of IP domains.
    If you have not created any custom IP domains, only the Default Domain appears in the list. This predefined domain has a 'null' setting for all parameters.
    Any custom domains that you have created have values for the following parameters:
    Name
    Identifies the domain.
    Description
    (Optional) Describes this domain namespace, such as naming the enterprise that owns it.
    Primary DNS Address
    Is the IP address of the primary name server for this domain.
    Primary DNS Port
    Is the port number that the primary name server uses.
    Secondary DNS Address
    Is the IP address of the secondary name server for this domain. Can be the same as the primary address.
    Secondary DNS Port
    Is the port number that the secondary name server uses.
    DNS Proxy Address
    Is the IP address of the DNS proxy server.
    DNS Proxy Enabled
    Indicates whether the proxy address is enabled for this IP domain.
