Views in CA Performance Center › CA Network Flow Analysis Views in CA Performance Center › Interface: Stacked Trend Charts › Stacked ToS Trend
Stacked ToS Trend
The Stacked ToS Trend views show the interface traffic for the top ToS, including the time the traffic occurred.
The example graphic shows a Stacked ToS Trend view that shows a timeline of rates for each listed ToS value. You can configure the view to display rate, utilization, or volume information.
The view includes the following information:
- Identifier
Consists of the router name, interface name, and interface description (under the view title). The interface description consists of the ifDescr value by default, so it may be slightly different than the interface description that is shown in CA Network Flow Analysis.
- ToS Bands
Show the data rate, data volume, or interface capacity utilization for each Top N ToS that is associated with traffic on the interface.
- Time (All Views)
Point in time during data transmission--expressed in hours and minutes (X-Axis).
- Measurement Setting:
- Rate: Data transfer rate at each point in time--for example, expressed in kilobits per second (Y-Axis). The rate is calculated by dividing the data volume by the elapsed transmission time.
- Bytes (Volume): Data volume at each point in time--for example, expressed in kilobytes (Y-Axis).
- Percent (Utilization): Percentage of the total interface capacity that the ToS traffic uses (Y-Axis). The utilization percentage is calculated by dividing the data rate by the data speed.
Depending on the data direction, the measured data is inbound to the interface, outbound from the interface, or both.
- Legend
Identifies the ToS for each color band by ToS number and label (bottom of the view).
By default, views and reports show the most recent 24 hours of data.
To see the Stacked ToS Trend views in CA Performance Center, go to one of the following locations:
Available Actions for This View
You can perform several actions in this view, including the following actions:
- Change the traffic direction, the type of measurement and the view name by editing the view settings. If the view is on a custom interface context dashboard, you can change the interface.
- Zoom in to narrow the time frame.
- Display only the data for a single ToS: Right-click a ToS in the legend at the bottom of the view and click Focus. This menu is available for a view that has multiple ToS values. (This option is active when the view contains multiple ToS values.)
- Hide data for one of multiple ToS values: Right-click a ToS in the legend at the bottom of the view and click Hide.
- Position your cursor over legend items to display explanatory Tooltips.
- Jump to details on a CA Network Flow Analysis Interfaces page by double-clicking a ToS value in the legend.
Find ToS Trend Data in NFA Console Views and Reports
You can display ToS volume in trend charts or stacked trend charts in the NFA console for a selected interface:
- Overview -- Report type: Overview. Presentation menu options: Mixed Chart or Mixed Trend; Volume.
Views: Stacked ToS Trend (In and Out) for the Top N ToS, plus other overview views.
- Top N ToS, Stacked Trends -- Report type: ToS. Filter: Top N ToS. Presentation menu options: Stacked Trend Chart; Volume.
Views: Stacked Trend for the Top N ToS (In, Out, and Total).
- Top N ToS, Trends -- Report type: ToS. Filter: Top N ToS. Presentation menu options: Trend Chart; Volume.
Views: Trend (In, Out, and Total) for each of the Top N ToS.
- Single ToS, Stacked Trends/Trends -- Report type: ToS. Filter: Single ToS value. Presentation menu options: Mixed Trend; Volume.
Views: Trend (In and Out with baselines), Stacked ToS Trend (In and Out).
- Single ToS, Trends -- Report type: ToS. Filter: Single ToS value. Presentation menu options: Mixed Chart; Volume.
Views: Stacked ToS Trend (In and Out).
- Conversation -- Report type: Conversations. Filter: Single conversation source and destination. Report subtype: Protocols. Presentation menu options: Volume.
Views: Conversation Trend (maximum of 7 views for different timespans).
To display Flow Forensics-level detail, click the Flow Forensics link and run a Flow Forensics report.
