Previous Topic: Build a Custom ViewNext Topic: Sharing Data with Other Users
Build a Custom View for a Single Interface
You can create custom views that contain CA Network Flow Analysis data for a single interface. You can add these interface views to a custom dashboard.
Several interface views are available in addition to the views that are displayed by default on the interface pages.
  1. Log in as a user with the required administrative role rights.
  2. Navigate to the dashboard page in CA Performance Center where you want to add a custom view.
  3. Click the More menu, and select Edit Dashboard.
    The Edit Dashboard Layout page opens.
  4. Click the Select Context link in the Views pane.
    The Select View Context dialog opens.
  5. Select Interface from the Context Type list.
    A table of routers and interfaces appears.
  6. Locate and select an interface in the table.
    A long identification string for the router and interface appears in the Context Item field.
  7. Click OK.
    You return to the Edit Dashboard Layout page.
  8. Expand the IP Flow category.
  9. Drag one or more of the CA Network Flow Analysis interface views into the layout.
  10. Click Save to save the change to the dashboard.
    The dashboard page refreshes.
