A standalone configuration consists of one server that hosts the NFA console and the Harvester. Complete the steps in this topic to install all of the CA Network Flow Analysis components on a single Windows server or virtual machine.
Before You Begin: Verify that the installation server meets the following requirements:
Follow these steps to complete the Harvester phase of the installation:
A check verifies that the installation server has a supported version of the Java Runtime Engine (JRE) installed. If the check fails, an error message opens. You cannot launch the upgrade program until this problem is corrected.
If the server passes the Java prerequisite check, the program starts and the language selection screen opens.
The Welcome screen opens.
Click Next in the Welcome screen.
The CA NFA Harvester License Agreement screen opens.
Prerequisite tests are run to identify problems on the server. If a a problem is found, an error message opens. A critical problem causes the program to exit. A Pre-requisite Check Warning message or other warning message opens for non-critical problems, which gives you the option to make corrections now or after the installation or upgrade is complete.
The default location is C:\CA\NFA. We recommend that you install CA Network Flow Analysis components on a nonsystem drive that you have set up for CA Network Flow Analysis. The NFA console will be installed to the same directory that you choose for the Harvester.
The Select a Location for the MySQL Data Directory screen opens after a moment. This screen shows the default installation path for the MySQL data directory.
We recommend that you use a drive that has at least 40 GB of available space for the database.
The Select a Location for the MySQL Temp Directory screen opens, which shows the default installation path for the MySQL tmp directory.
MySQL51 is configured, then the Pre-Installation Summary screen opens.
The Installing Harvester screen opens, which shows the progress. When the installation is complete, the Install Complete screen opens and reports any errors that occurred.
<NFA_install_path>/Harvester_Install_MM_DD_YY_hh_mm_ss.log (where MM_DD_YY_hh_mm_ss reflects the timestamp)
The Harvester installation program closes.
Follow these steps to complete the NFA console phase of the installation:
A check verifies whether a supported version of the Java Runtime Engine (JRE) is installed. If the check fails, an error message opens. You cannot launch the upgrade program until this problem is corrected.
The NFA Console License Agreement screen opens.
The Third-Party License Agreement screen opens.
Prerequisite tests are run on the installation server. If an error message opens that requires attention, see Troubleshooting.
A test verifies that the installed version of CA Network Flow Analysis is supported for upgrade. The Singlebox Confirmation message opens when the verification is complete. This message asks you to confirm that you want a standalone deployment of CA Network Flow Analysis.
The Pre-Installation Summary screen opens after a moment.
The Installing NFA screen opens. Progress is shown in the status bar and messages. When the NFA console installation is complete, the Install Complete screen opens.
The NFA console is installed and your system is ready for post-installation configuration.
Next: Complete the post-upgrade tasks.
