Previous Topic: Software CompatibilityNext Topic: Installation and Upgrade Prerequisites
Co-Installation
You can install CA Anomaly Detector on the same server that hosts CA Network Flow Analysis and CA NetQoS Performance Center software or you can install the products on separate servers. The following table shows the supported configurations for co-installing CA Anomaly Detector with other related software.
Notes:
Components Installed on a Single Server
Supported?
CA Anomaly Detector (AD) with no other related software component
Yes
NFA standalone (Harvester + NFA console) + AD
Yes
NFA console + AD
Yes
NPC + NFA standalone (Harvester + NFA console) + AD
Yes
NPC + NFA console + AD
Yes
NPC + Event Manager* + NFA standalone (Harvester + NFA console) + AD
Yes
NPC + Event Manager* + NFA console + AD
Yes
ADA (SA), UCM, or NetVoyant + AD or any NFA component
No
* If the Event Manager is co-installed with CA Network Flow Analysis, the trap receiver in CA Network Flow Analysis is disabled automatically.
