CA Network Flow Analysis 9.1.3 runs with CA Anomaly Detector 9.1.3, but not with previous versions of CA Anomaly Detector. You must upgrade any previous version of CA Anomaly Detector that is currently installed.
CA Anomaly Detector requires that certain software is installed in your environment. The following table describes which software versions are supported:
Program |
Supported Version |
Required? |
CA Anomaly Detector installation that you intend to upgrade * |
2.2.16 |
Required if upgrading |
CA NetQoS Performance Center |
6.1.194 (version 6.1 update 1, build 194) |
Required |
Event Manager |
2.1.116 |
Optional ** |
CA Network Flow Analysis (one instance) |
9.1.3 *** |
Required |
CA NetVoyant (one instance) |
7.1.65 |
Optional |
CA Application Delivery Analysis (SuperAgent) (one or two instances) **** |
9.3.78 |
Optional |
CA Unified Communications Monitor (one or two instances) **** |
3.5.186 |
Optional |
* If you have a version of CA Anomaly Detector that is earlier than version 2.2.16, upgrade to version 2.2.16 before you begin.
** If the Event Manager is installed in the deployment and registered with CA NetQoS Performance Center, anomaly events are visible in the CA NetQoS Performance Center Console Events page.
*** CA Anomaly Detector functionality is enabled by the CA Network Flow Analysis 9.1.3 software.
**** These programs must be installed on a server that does not host CA Anomaly Detector or any CA Network Flow Analysis component.
