Complete the steps in this topic to install CA Anomaly Detector on a Windows server or virtual machine.
If the same server hosts CA Anomaly Detector and CA NetQoS Performance Center or CA Network Flow Analysis, follow the installation order described in Co-Installation. The steps are written with the expectation that you have already installed any related products that will be co-located with CA Anomaly Detector.
Burn the ISO file to a CD-ROM or DVD-ROM or extract the contents of the ISO file by using an ISO image software application.
Whether you plan to install the software locally or remotely, put the installation file on the installation server.
The installation program opens.
The Welcome screen opens.
The Pre-Installation Summary screen opens.
The Choose Install Folder screen opens.
Use the same installation folder for CA Anomaly Detector and the NFA console or standalone installation. The default location is C:\CA\NFA. We recommend that you install CA Anomaly Detector on a nonsystem drive.
The Installing AD screen opens, which shows the progress of the installation. When the installation is complete, the Install Complete screen opens and verifies that the installation was successful.
<install_path>\AD_Install_<timestamp>
The installation program closes.
Next: Complete the post installation tasks.
