We recommend that you disable User Account Control (UAC) on any Windows Server 2008 R2 system that is used as the standalone server or NFA console server. UAC is not fully supported for the current version of CA Network Flow Analysis. Enabling UAC on the standalone server or NFA console server can result in unexpected behavior.
Note: UAC is not applicable to Windows Server 2003 systems.
Required/Optional |
Operating System |
Servers to Configure |
Recommended |
Windows Server 2008 R2 |
Standalone, Console |
The Control Panel opens.
The User Accounts window opens.
The User Account Control Settings dialog opens.
UAC is set to be disabled for all local accounts on the server.
You return to the User Accounts tasks page.
