Four traps in ReporterAnalyzer 9.0.1 had conflicting Object Identifiers (OIDs). The conflicts could create problems with the trap receiver, which could not use the trap OID to determine which type of trap to process. The traps with conflicting OID values were:
To resolve the overlap, the Harvester traffic traps have been moved to a new OID section, and the MIB has been rewritten to reflect this change. The updated MIB is on the NFA console server in the following directory: <install_path>\reporter\MIB. Use the following table to make any necessary updates to the values for processing the ReporterAnalyzer or CA Network Flow Analysis traps that you use.
If your trap receiver processes Watchdog traps only, you do not need to update any definitions.
Note: The highlighted table rows show OID values that have been updated.
OID Name |
Updated OID Value |
Previous OID Value |
nfaInterfaceChangeName |
1.3.6.1.4.1.4498.10.2.1 |
1.3.6.1.4.1.4498.1.1.1.1 |
nfaInterfaceChangeState |
1.3.6.1.4.1.4498.1.1.1.2 |
1.3.6.1.4.1.4498.10.2.2 |
nfaDataEventName |
1.3.6.1.4.1.4498.10.2.3 |
1.3.6.1.4.1.4498.1.2.1.1 |
nfaDataEventInterface |
1.3.6.1.4.1.4498.10.2.4 |
1.3.6.1.4.1.4498.1.2.1.2 |
nfaDataEventDirection |
1.3.6.1.4.1.4498.10.2.5 |
1.3.6.1.4.1.4498.1.2.1.3 |
nfaDataEventStartTime |
1.3.6.1.4.1.4498.6.2.6 |
1.3.6.1.4.1.4498.1.2.1.4 |
1.3.6.1.4.1.4498.10.2.6 |
nfaDataEventDuration |
1.3.6.1.4.1.4498.10.2.7 |
1.3.6.1.4.1.4498.1.2.1.5 |
nfaDataEventStopTime |
1.3.6.1.4.1.4498.10.2.8 |
1.3.6.1.4.1.4498.1.2.1.6 |
nfaDataEventResetReason |
1.3.6.1.4.1.4498.6.2.9 |
1.3.6.1.4.1.4498.1.2.1.7 |
nfaDataEventRouterAddress |
1.3.6.1.4.1.4498.10.2.10 |
1.3.6.1.4.1.4498.1.2.1.8 |
nfaDataEventIfIndex |
1.3.6.1.4.1.4498.10.2.11 |
1.3.6.1.4.1.4498.1.2.1.9 |
nfaTrafficProtocol |
1.3.6.1.4.1.4498.10.2.12 |
1.3.6.1.4.1.4498.1.101.1.1 |
nfaTrafficProtocolThreshold |
1.3.6.1.4.1.4498.10.2.13 |
1.3.6.1.4.1.4498.1.101.1.2 |
nfaTrafficProtocolObserved |
1.3.6.1.4.1.4498.10.2.14 |
1.3.6.1.4.1.4498.1.101.1.3 |
nfaTrafficProtocolToS |
1.3.6.1.4.1.4498.10.2.15 |
1.3.6.1.4.1.4498.1.102.1.1 |
nfaTrafficProtocolToSValue |
1.3.6.1.4.1.4498.10.2.16 |
1.3.6.1.4.1.4498.1.102.1.2 |
nfaTrafficProtocolToSThreshold |
1.3.6.1.4.1.4498.10.2.17 |
1.3.6.1.4.1.4498.1.102.1.3 |
nfaTrafficProtocolToSObserved |
1.3.6.1.4.1.4498.10.2.18 |
1.3.6.1.4.1.4498.1.102.1.4 |
nfaTrafficFlowsThreshold |
1.3.6.1.4.1.4498.10.2.19 |
1.3.6.1.4.1.4498.1.103.1.1 |
nfaTrafficFlowsObserved |
1.3.6.1.4.1.4498.10.2.20 |
1.3.6.1.4.1.4498.1.103.1.2 |
netQoSEventName |
1.3.6.1.4.1.4498.1.3 |
netQoSProcessName |
1.3.6.1.4.1.4498.1.4 |
netQoSProcessID |
1.3.6.1.4.1.4498.1.5 |
netQoSServerAddress |
1.3.6.1.4.1.4498.1.6 |
netQoSResourceName |
1.3.6.1.4.1.4498.1.7 |
netQoSResourceID |
1.3.6.1.4.1.4498.1.8 |
netQoSProcessDelay |
1.3.6.1.4.1.4498.1.9 |
netQoSProcessDelayThreshold |
1.3.6.1.4.1.4498.1.10 |
netQoSResourceUtilization |
1.3.6.1.4.1.4498.1.11 |
netQoSResourceUtilizationThreshold |
1.3.6.1.4.1.4498.1.12 |
nfaInterfaceChangeEvent |
1.3.6.1.4.1.4498.10.1.0.1 |
1.3.6.1.4.1.4498.1.0.1 |
nfaTrafficProtocolDataEventStart |
1.3.6.1.4.1.4498.10.1.0.2 |
1.3.6.1.4.1.4498.1.0.6 |
nfaTrafficProtocolDataEventStop |
1.3.6.1.4.1.4498.10.1.0.3 |
1.3.6.1.4.1.4498.1.0.7 |
nfaTrafficProtocolToSDataEventStart |
1.3.6.1.4.1.4498.10.1.0.4 |
1.3.6.1.4.1.4498.1.0.8 |
nfaTrafficProtocolToSDataEventStop |
1.3.6.1.4.1.4498.10.1.0.5 |
1.3.6.1.4.1.4498.1.0.9 |
nfaTrafficFlowsDataEventStart |
1.3.6.1.4.1.4498.10.1.0.6 |
1.3.6.1.4.1.4498.1.0.10 |
nfaTrafficFlowsDataEventStop |
1.3.6.1.4.1.4498.10.1.0.7 |
1.3.6.1.4.1.4498.1.0.11 |
netQoSProcessStart |
netQoSProcessStop |
netQoSProcessDelayStart |
netQoSProcessDelayEnd |
netQoSResourceEventStart |
1.3.6.1.4.1.4498.1.0.12 |
netQoSResourceEventEnd |
1.3.6.1.4.1.4498.1.0.13 |
Next: Complete the configuration tasks in the CA Network Flow Analysis Administrator Guide section named "Initial Configuration."
