The CA Network Flow Analysis 9.1.3 includes an option to uninstall the product, which you can use to remove CA Network Flow Analysis after an installation or upgrade.
Notes:
Do not use the Uninstall option if you have upgraded from CA NetQoS ReporterAnalyzer 9.0.1. To successfully reinstall the software in this case, you must first re-image the system.
This section contains the following topics:
Uninstall CA Network Flow Analysis
