Before you upgrade a CA Network Flow Analysis 9.1.00 or 9.1.1 deployment, back up the databases and files that are listed in the following table.
Important:
Database |
Description |
Standalone Server |
Harvester Servers (Distributed) |
NFA Console Server (Distributed) |
reporter |
Enterprise Overview data and NFA console configuration data |
Important |
Important |
harvester |
Harvester configuration data |
Important |
Important |
poller |
Poller configuration data |
Important |
Important |
ReaperArchive15 |
Historical (15-minute) data |
Recommended |
Recommended |
Customized Files |
Configuration or other files that have been customized |
Important |
Important |
Important |
Customized data_retention |
Settings to regulate data retention |
Important if customized |
ReaperArchive |
Realtime (1-minute) data |
Optional, rarely backed up |
Windows Registry |
Settings for the Windows Harvesters |
Important (Windows Harvesters) |
The following list describes the databases and their locations:
Path: <install_path>\MySql51\data\reporter directory
Path: <install_path>\MySql51\data\harvester directory
Path: <install_path>\MySql51\data\poller directory
Path: <install_path>\Netflow\datafiles\ReaperArchive15 directory
The CA Network Flow Analysis configuration files typically have a .config, conf., or .ini extension and are located in the product installation path. Other customizations may include .css files and report logos.
Path: <install_path>\Netflow\datafiles\ReaperArchive directory
Path: <install_path>\MySql51\data\data_retention directory
Back up the Registry as a .reg file by selecting File, Export in the Registry Editor window. For more information about the new location of Harvester settings, see the Release Notes topic "Relocation of Harvester Settings."
