Access to the NFA console is supported for Microsoft Internet Explorer version 7 or 8. Version 8 is recommended. Other browsers or browser versions may work with CA Network Flow Analysis, but have not been tested. Microsoft Internet Explorer version 10 is not supported.
Required/Optional |
Operating System |
Servers to Configure |
Recommended |
Windows Server 2003. Windows Server 2008 R2 |
NFA console server Standalone server |
Required |
Servers that are used to log into the NFA console |
Note: To set up CA Network Flow Analysis and work with data in the CA Performance Center Console, use Internet Explorer 8 with compatibility mode turned off. To work in CA Network Flow Analysis directly, you can use Internet Explorer 7 or 8 with compatibility mode turned on or off.
If Internet Explorer 8 Developer Tools are installed, you can turn off compatibility mode for the current browser session:
If your enterprise has a policy that requires the Internet Explorer 8 browser to operate in compatibility mode, you may want to use Internet Explorer 7.
