Initial Configuration › Set Up Flow Cloning › Prerequisites for Flow Cloner Installation
Before you install the Flow Cloner, verify that your installation server meets the following prerequisites:
- Verify that the server is configured and installed or upgraded as described in the CA Network Flow Analysis Installation Guide or Upgrade Guide.
- Verify that the server already has software installed and configured to act as one of the following components:
- Windows Harvester server in a CA Network Flow Analysis 9.1.3 distributed deployment
- Standalone server in a standalone deployment.
- Verify that the server has at least 12.8 MB of disk space is available on the target drive for the Flow Cloner.
- Exit from all other programs.
- Verify that no other user is logged in to the server.
