Previous Topic: Prerequisites for Flow Cloner InstallationNext Topic: Configure Flow Cloner Options
Install the Flow Cloner
Use the steps in this topic to install the Flow Cloner.
  1. Log in to the Windows-based Harvester installation server as a user with administrator privileges.
    The installation server must have the CA Network Flow Analysis 9.1.3 Harvester software installed.
  2. Locate the installation program file: <install_path>\setup\FlowClonerSetup.exe.
  3. Start the installation program: For example, double-click the FlowClonerSetup.exe file in Windows Explorer.
  4. Click Next in the Welcome screen that opens.
    The Pre-Installation Summary screen opens and shows you the installation path and disk space requirements. The Flow Cloner will be installed in the same root installation directory that is used for the Harvester or standalone software. The default installation path is the same as the installation path for the Harvester or CA Network Flow Analysis standalone deployment.
  5. Click Install in the Pre-Installation Summary screen.
    The status bar and pop-up messages show the progress of the installation. The Install Complete screen opens when the installation is complete.
  6. Click Done in the Install Complete screen.
    The installation program closes. An installation log file named FlowCloner_Install_<timestamp>.log is created in the root installation directory.
Next: Configure the Flow Cloner options.
