Use the Search function on the Active Interfaces page to locate routers, interfaces, or CVIs. To search for aggregations, use the similar Search function on the Aggregation Interfaces page.
The Active Interfaces page opens, which lists the current routers and their active interfaces.
Note: Do not use wildcards.
The list is filtered to display only matching entries. If you search for interfaces or CVIs, the search returns a list of routers that contain matching items. When you expand router details, all items appear in the sublists.
To clear the search, click Clear Filter.
