Previous Topic: View Physical and Virtual InterfacesNext Topic: Search for a Router, Interface, or CVI
Review the Active Interface Page Options
Use the Active Interfaces page to view and manage active routers, interfaces, and custom virtual interfaces (CVIs).
  1. Open the Active Interfaces page:
    1. Select Administration from the NFA console menu.
    2. Select Interfaces: Physical & Virtual from the Administration menu.
      The Active Interfaces page opens, which lists the current routers and their active interfaces.
    The Active Interfaces page contains a table of routers with interface details.
The Active Interfaces page includes the following options:
Router Table Elements
Routers are listed on the Active Interfaces page in the form of tables. The router tables contain the following columns.
Table Columns
Interface Table Elements
Interfaces and custom virtual interfaces (CVIs) are listed on the Active Interfaces page in tables nested under their parent routers. To display the interfaces and CVIs for a router, click the arrow next to the router name. Interface tables contain the following elements and columns.
Table Columns
