Previous Topic: Troubleshoot Issues with Integrated TrapsNext Topic: Service Management
Expire Stale Addresses
IP addresses can be automatically assigned by Dynamic Host Configuration Protocol (DHCP), and addresses can become outdated. You can expire stale (outdated) IP addresses to schedule them for refresh. You also can change the frequency of DNS name updates when you edit an address.
The program checks the DNS server and refreshes the DNS name for with each expired address.
  1. Display the Address-Hostname Configuration page:
    1. Select Administration from the NFA console menu.
    2. Select Reporting: Addresses from the Administration page menu.
      The Address-Hostname Configuration page opens.
  2. (Multiple domain environment only) Select the tenant-domain combination that contains the address you want to refresh.
  3. Click List.
    A list opens, which shows the addresses for the selected domain.
  4. Click the check box next to each address that you want to expire.
  5. Click Expire, then confirm the expiration when the prompt opens.
    The selected addresses are scheduled to have their DNS resolution refreshed. The refresh process is typically run within 5 minutes.
