Previous Topic: Fragmented Packet SourcesNext Topic: Large ICMP Packet Sources
Large DNS Packet Sources
The Large DNS Packet Sources sensor looks for DNS requests that are larger than typical requests. Such packets may indicate tunneling attempts or data exfiltration.
Troubleshooting a Large DNS Packet Sources Alert
An alert from the Large DNS Packet Sources sensor may indicate data exfiltration activity. Data ex-filtration is a network security violation in which a user discreetly attempts to send data from an internal network to an external location.
If you suspect data ex-filtration, click the link for the offending host to investigate the suspected user by using a Flow Forensics report in CA Network Flow Analysis. For more information, see Built-in Workflows. You can also use other packet-inspection tools (such as CA GigaStor) to identify the data that was sent.
