CA Network Flow Analysis provides information to help you understand how application traffic affects your network’s performance. CA Network Flow Analysis enables you to see which applications are using bandwidth, who is using the bandwidth, and when. By knowing which applications and users are consuming bandwidth, you can make timely and cost-effective decisions to optimize network performance.
When you add CA Network Flow Analysis as a data source for CA NetQoS Performance Center, the Harvesters in the deployment are added automatically as possible data sources for CA Anomaly Detector. Special considerations apply when you enable Harvesters as data sources. For additional information about adding Harvesters, see Best Practices: Slow Harvester Rollout.
