After you create a protocol group and operators run reports that use the protocol group as a filter, you may want to make changes.You may want to rename the protocol group to reflect the way operators are likely to use it. You also may want to change the list of protocols included in the group.
The Edit a Protocol Group page opens.
The name and description are updated in the Protocol Group Configuration page list and in the Protocol Group Index.
A table is added to the bottom of the page, which lists the protocols.
For more information about the Domain setting, see Step 3 in Configure the Protocol Group.
For more information about this step, see Step 4 in Configure the Protocol Group.
The protocol group is configured with your settings. As soon as the next synchronization in CA Performance Center is complete, the revised protocol group is available to operators who are defining an Analysis or Custom report.
