Previous Topic: Review the Protocol Group Settings
Next Topic: Create and Manage ToS Groups
Label ToS Values
You can create labels (or descriptions) for ToS values to ensure that users know which service is associated with each ToS value. If you do not label ToS values, the numeric ToS value is displayed by default.
Note: The ToS labels that you create affect all uses of the ToS in the assigned domain, but do not affect ToS labels in other domains.
  1. Open the ToS Configuration page:
    1. Select Administration from the NFA console menu.
    2. Select ToS Names from the Administration page menu.
      The ToS Configuration page opens and displays information about the selected ToS and domain.
  2. (Multiple-domain environment only) Select the domain that contains the ToS values that you want to edit.
  3. Select a ToS value from the list, then click Edit.
    The Description becomes editable.
  4. Enter the new description for the ToS value in the Description box and click Save.
    Your change is saved and the Description and Value fields for the selected ToS are updated.
Note: You can also use the ToS Configuration page to add or delete ToS values to ToS groups. Select the domain and ToS value, then click the Add/Remove link at the top of the ToS groups list. The ToS Group Index dialog opens, which you use to make changes for user-configured groups. (You cannot change the built-in All ToS group.)
