You can change the context for a single view on a dashboard. Change the context of an enterprise-wide view to show data from a different set of managed items. Change the context of an interface-specific view to show data from a different interface.
Changing the context for a view is useful for troubleshooting performance issues. For example, you can use your group structure to compare data from different geographical regions.
The View Settings dialog opens.
The context types that are available depend on the type of view.
Note: The availability of these options depends on your user account role rights.
The view is updated with data from the new context.
You can also change the context for a dashboard, which applies the selected group or managed item as a filter to all views on the page.
