Previous Topic: Customizing Views
Next Topic: Change the Context for a View
View Options
Many views offer a search feature and other settings that you can change to modify the view. In addition to filtering and time frame options, the following options are available for most data views:
Other view options are specific to the selected view. The available options depend on the format and data source.
Trend View Options
The trend views that are available in context pages let you quickly and easily change the trend lines that are displayed on the graph. The following options also apply to multitrend views:
Trend views also include an option to add a "goal line" as a visual indication of performance levels or thresholds. You can supply any value or label for the goal line, and you can show or hide the goal line for a selected trend view.
Table View Options
In table views, you can drill down to detailed data for individual items. Use the page feature to see metrics from a longer list of items. Increase the Max Per Page value to increase the size of the view and the number of table rows per page.
You can sort table data columns by selected metrics and also select columns to include. Click a table column to sort. A white arrow on the column lets you access a menu of table column options. Select Columns to enable and disable the metrics that were enabled for the table by default.
Change the View Settings
You can change several settings for an enterprise-wide view or an interface-specific view. The available settings depend on the view that you are editing.
For example, some views have settings for data direction--so you can set the view to display inbound data, outbound data, or all data. Other views have settings for the type of measurement--so you can set the view to display data rates, data volumes, or interface capacity utilization.
  1. Open the dashboard that contains the view that you want to modify.
  2. (Optional) Change the time frame, if necessary.
  3. Click the Edit icon To change the view thresholds, click the Configure icon. in the view title bar and select Edit from the menu.
    The View Settings dialog opens.
  4. (Optional) Edit the view Title to change the text that appears in the view title bar.
  5. (Optional) If the view has Measurement Settings, select the type of measurement to show in the report:
  6. (Optional) If the view has Direction Settings, select the data direction on the selected interface:
  7. (Optional) For an interface-specific view, change the interface whose data is included: Select a different interface from the Context Settings table.
    Note: You can change the interface for an individual view on a custom dashboard that you defined with the Interface context. You cannot change the interface for standard views on other types of dashboards or on interface context pages.
    To re-sort the table, click a column heading. You can click the white arrow to choose between Sort Ascending and Sort Descending.
    To change the columns that are included in the table, display the Columns list: Click near the right edge of a column heading, then click the white arrow and select Columns.
  8. (Optional) For an enterprise-wide view, change the context to change the set of managed items that can be used in the view: Select a group in the Context Settings tree.
    For example, to restrict the interface set to a domain, select the domain from the IP Domains list.
  9. (Optional) Specify which users are affected by the setting changes: Select a value from the Apply Changes list:
    Note: The availability of these options depends on your user account role rights.
  10. Click Save to save your changes.
    The View Settings dialog closes. The view refreshes to reflect your updates.
Note: You can also change the context for a dashboard, which applies the selected group or managed item as a filter to all views on the page.
