Previous Topic: Top Protocols (Table)
Next Topic: View Options
Customizing Views
The icons at the top right of each data view give access to settings and other options that are associated with views. The View icons let you modify view settings, export views, and access context-sensitive online Help.
You can select predefined and custom time frames for dashboards to compare data that was collected at different times. The time frame setting affects all views on the same page. For a dashboard or for an individual view, you can change the data context to see data from another reporting group.
For some types of views, you can customize the table or chart format.
