IP domains are required for monitoring multiple environments with overlapping IP addresses. Set up all the domains that you will need before you begin to send flow data to CA Network Flow Analysis.
The Manage IP Domains page shows the current list of IP domains.
If you have not created any custom IP domains, only the Default Domain appears in the list. This predefined domain has a 'null' setting for all parameters.
Any custom domains that you have created have values for the following parameters:
Identifies the domain.
(Optional) Describes this domain namespace, such as naming the enterprise that owns it.
Is the IP address of the primary name server for this domain.
Is the port number that the primary name server uses.
Is the IP address of the secondary name server for this domain. Can be the same as the primary address.
Is the port number that the secondary name server uses.
Is the IP address of the DNS proxy server.
Indicates whether the proxy address is enabled for this IP domain.
